1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.?
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 05 Aug 2010 15:55:15 -0500
On 8/5/10 3:18 PM, Gary V. Vaughan wrote:
> My choices seem to be either building as root in the install tree, and
> then deleting the sources, or else relinking at install-time while I
> copy the libraries and binaries into their final location in order
> to make sure the RPATHs are set correctly.
Hi, Gary.
One variant on your first choice: If you're trying to install everything
into its own tree (e.g. /opt/epics-base-3.14.11) using the method you
mentioned of building in the install tree, you could avoid building as
root by temporarily changing the owner of the install tree to be the
user for the build.  Perform the build as that user, delete the sources,
then change the owner back to root.
Lewis
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Gary V. Vaughan
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Ralph Lange
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
