Subject: |
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 5 Aug 2010 16:45:10 -0500 |
Hi David,
On Thursday 05 August 2010 16:12:40 David Dudley wrote:
> Where I was having the problem, was in building the 'extensions' directory.
> A number of them appear to believe that the include files are at
> '../include', along with the 'configure' and 'bin' directories.
It sounds like you need to edit your extensions/configure/RELEASE file and
point EPICS_BASE to where your INSTALL_LOCATION was set for the Base build.
It defaults to assuming that base is at ../base but you can change that.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
RE: Making a case for cases Steiner, Mathias
<2010>
2025
2026
VxWorks and Radius Authentication Gary Carr
<2010>
2025
2026
