1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Making a case for cases
To: "Steiner, Mathias" <[email protected]>
Date: Thu, 05 Aug 2010 18:42:53 -0400
On 05.08.2010 18:00, Steiner, Mathias wrote:
I believe the solution is to have project leaders design the names into the system from the start. This might even make them think about controls ahead of time ;->
In a perfect world .... Well, good luck with that. It would be really great if it worked.
There needs to be an authority to make sure the proposed names pass muster. ":HVRd" isn't really worse or better than ":RdHV," but we don't want both.
I would suggest that first thing after your convention is agreed upon, you create a web-based parser, so that people can play around, validate their name ideas, and get used to the names.
The list of signal names will be ever growing. Put the authoritative list on the web and make people use existing names if they match the case, having the naming tsar add a new signal name, if it is something not covered yet.
Also, splitting up the signal name in two parts keeps your lists shorter:
- the signal (i.e. the unit, such as temperature, pressure, field, power, ...)
- the signal domain (i.e. the type, such as readback, setpoint, status, command, switch, selector)
Combining these two parts using CamelCase might yield quite nice-to-read yet short signal names, e.g.
PwrSt (power status), PwrSw (power switch), RstCmd (reset command), VoltSet, ... you get the idea.
Caveat: you might have to integrate things like a "voltage threshold setpoint" or a "temperature range selector" or reading back a setpoint, which need a bit more thought.
A small committee might be indicated; I envision three or four people from different departments, preferably the kind who hate meetings...
A name oligarchy ... might be more fun than just one tsar.
Good luck!
Ralph
Re: Making a case for cases George Lahti
RE: Making a case for cases Zhukov, Alexander P.
medm Mezger Anton-Chr.
Re: Making a case for cases Steven M. Hartman
Re: Making a case for cases Purcell, J. David
Re: Making a case for cases Andrew Johnson
RE: Making a case for cases Steiner, Mathias
Prev: Re: Making a case for cases Alan Biocca
Next: Re: Making a case for cases Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Making a case for cases Steiner, Mathias
Next: Re: Making a case for cases George Lahti
