IIRC there is a 'S' checkbox for the widget (in edit mode: open x-y
graph's
'trace properties' dialog) where you can say that the data is signed
(unsigned
if unchecked). There is no other way for edm to know since there are no
signed/unsigned CA cardinal types.
T.
On 08/13/2010 12:22 AM, Eric Norum wrote:
I've got an application with a waveform record with FTVL=SHORT:
record(waveform, "$(P)SetPattern") {
field(DESC, "Bunch cleaner pattern (-1,0,1)")
field(NELM, "328")
field(FTVL, "SHORT")
field(FLNK, "$(P)EncodePattern")
caget can read this out just fine:
caget bcleanSetPattern
bcleanSetPattern 328 -1 -1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1
but EDM (1-12-33 on linux) treats the -1 as unsigned and thus plots 65535 rather than -1:
Any suggestions?
- EDM and waveform records with FTVL=SHORT Eric Norum
Re: ASYN Addition Andrew Wagner
Using spectrumRecord of the waveProc module Condamoor, Shantha
<2010>
2025
2026
Re: EDM and waveform records with FTVL=SHORT Eric Norum
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
