1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DataBase question
To: <[email protected]>
Date: Mon, 16 Aug 2010 15:15:15 -0400
On 08/16/10 15:05, Andrew Wagner wrote:
Hey guys,
I'm building a database to ramp a magnet given inputs from an Agilent 34970 MUX and output to an Agilent 3631 Voltage programmer. I've got the drivers and device support working for the MUX and programmer and would like to create a database (and separate application) that can access the AI and AO records from the devices and and perform calculations. My question is: Do records loaded in the same IOC have access to each others PVs? For instance if I :
dbLoadRecords("db/devAG34970.db",args)
dbLoadRecords("db/devAG3631.db",args)
to load the AI and AO records for the devices, can I have a third record,
dbLoadRecords("db/MagnetCtrl.db",args)
that contains calc records that have inputs from pvs defined in the devAG records?
affirmative. The links are resolved when you call iocInit.
> Alternatively, do I have to define one big record that includes everything I want.
you mean one big (.db) database. It will work the other way so not needed.
Matthieu
Cheers,
Andrew
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
DataBase question Andrew Wagner
Prev: Re: DataBase question Ralph Lange
Next: Re: DataBase question Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
