Hi Andrew,
Replies embedded:
On 8/17/2010 6:13 PM, Andrew Wagner wrote:
Hey again,
I'm pretty close to having my magnet ramp code implemented but I need to know how to have a record access a user defined input during run time. For instance I want to turn a dial in MEDM to set the ramp point of the magnet. So far I've implemented a database as follows:
#Calc Coil Current
record(calc, "Current:Coil") {
field(DESC, "Coil Current")
field(SCAN, "Passive")
field(MDEL, ".1")
field(ADEL, ".1")
field(CALC, "LA + A*1/1200")
This expression won't be understood. You could say this:
field(INPB,"Current:Coil.A")
field(CALC,"B+A*1/1200")
field(INPA, "$(MUX):VOLT:Chan204.VAL PP MS")
field(PINI, "NO")
field(EGU, "A")
field(SDIS, "0")
#Calc output and write to AG3631 Voltage programmer
record(calcout, "Voltage:Output") {
field(DESC, "Output Voltage")
field(SCAN, "1 second")
field(CALC, "Voltage:Output.VAL + (B - A)*.5/1")
This calc expression won't be understood. You could say this:
field(INPC,"Voltage:Output.VAL")
field(CALC,"C + (B - A)*.5/1")
field(INPA, "Current:Coil.VAL PP MS")
field(INPB, "Runtime Input") # How do I link to user input?
You can either use a separate record, and point INPB at that record's
VAL field, or
you can have the user write directly to Voltage:Output.B. The first
solution is better
if you want to enforce limits or attach engineering units, precision, a
description, etc.
The two choices can't in this case make any difference in the algorithm,
because
Voltage:Output is periodically scanned. If it were "Passive", writing
directly to B
from a CA client would process the calcout record whenever the user
wrote, but
using the INPB link to read from a separate record would not have this
effect.
field(OOPT, "On Change")
field(DOPT, "CALC")
field(DTYP, "AG3631")
field(OUT, "#L$(L) $(A) @0")
field(PINI, "NO")
field(EGU, "V")
field(SDIS, "0")
How do I set the INPB to link to a runtime input? I've seen an example where a "dummy" AI record is linked, but I'm not sure if there is a better way. I would also like to put some protection logic in place. For instance, I would like to calculate a V_min and V_max (functions of Current:Coil) that Voltage:Output must be between in order for the OUT link to be processed. Are there any examples of how to implement this? The documentation doesn't really have any. Thanks again for your help.
You could use a separate output record, and have two calcout record's
write to its DRVH and DRVL
fields. This would clip the output at those values.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group, Advanced Photon Source, Argonne National Lab.
- Re: Runtime Input Question Ned Arnold
- Runtime Input Question Andrew Wagner
sCalcout Pierrick Hanlet
<2010>
2025
2026
<2010>
2025
2026
