Hi Jeff,
There is nothing to trace. The process is not there any more. The
gateway process just ends without any message. Just as if something has
called exit().
My start line is:
export EPICS_CA_MAX_ARRAY_BYTES=4000000
ulimit -s 2048
export EPICS_CAS_BEACON_ADDR_LIST=172.21.10.255
caGateway -no_cache -archive -prefix FIN-CCAGW11W-EXP \
-sip 172.21.10.22 \
-cip 172.21.11.255 \
-uid 922 -gid 922 \
-pvlist GATEWAY.pvlist \
-access GATEWAY.access \
-log gateway.log \
"$@" > gateway.err 2>&1 < /dev/null &
Gateway startup log:
Aug 19 15:32:36 PV Gateway Version 2.0.4.0 [Oct 16 2009 10:54:59]
EPICS 3.14.11 PID=4757
EPICS_CA_ADDR_LIST=172.21.11.255
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CAS_INTF_ADDR_LIST=172.21.10.22
EPICS_CAS_SERVER_PORT=Not specified
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Running as user cagw on host fin-ccagw11w
Statistics PV prefix is FIN-CCAGW11W-EXP
There is nothing in gateway.err and no error message in gateway.log with
a time stamp near the crash. The usual goodbye message like "Jul 13
17:12:40 PV Gateway Ending (SIGTERM)" is missing.
I will try to enable core dumps. Haven't done that yet.
Dirk
Jeff Hill wrote:
Hi Dirk,
I did put some considerable effort into improving the quality (in terms of
efficiency, stability, performance, and functionality) of the PCAS and the
gateway around this time last year. And I believe that the result was a
significant step forward. Which version of the gateway are you running?
Currently, I have no clues on your issue to start with so it's hard to move
forward. So I will 2nd Andrew's suggestion of attaching gdb and getting a
stack
trace of the failed thread. One can attach gdb to a running process by
typing
"gdb <full path to image> <process id>". If gdb can't be attached to the
running process then another alternative is to attach gdb to the core
file using "gdb <full path to image> <full path to core file>".
In gdb type first "bt" to show the
thread that crashed and then follow that with "thread apply all bt" so that
I know what all threads are up to when the crash occurred. Lots of output
but
exactly what is needed to get the matter resolved. This works better if the
code is compiled for debugging, but I might be able to resolve the issue
with
only the stack traces from the optimized version (which runs faster and so
can have a different set of failure scenarios) - so I am very willing to
look at traces from an optimized version first if it will save some effort
on your end.
Thanks in advance for your help,
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
-----Original Message-----
[email protected]] On Behalf Of Dirk Zimoch
Sent: Thursday, August 19, 2010 7:52 AM
To: EPICS
Subject: CA gateway dies without error message
Hi all,
Since upgrading the EPICS base version of the caGateways to 3.14.11,
the
gateway dies from time to time for no obvious reason. It does not write
any log message when it dies (as it would do in a clean shutdown, in
case of a signal or when any strange CA event happens.) It also does
not
write anything to stderr. I cannot remember that I have seen this type
of fault with 3.13.8.
Any idea?
Dirk
- RE: CA gateway dies without error message Jeff Hill
- CA gateway dies without error message Dirk Zimoch
msi again Benjamin Franksen
Re: hex stream processing with StreamDevice? Dirk Zimoch
<2010>
2025
2026
<2010>
2025
2026
