1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: hex stream processing with StreamDevice?
To: "Barker, Alan M." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 20 Aug 2010 08:45:54 -0700
Adding an interpose layer like this is how I handled the case of reading some arbitrary-length binary data using streamDevice.   Contact me if you'd like to have a look at this.  It's not 100% tested so I don't want to post it everywhere yet.
On Aug 20, 2010, at 3:14 AM, Dirk Zimoch wrote:
> Alan,
> Maybe you should try to write an interpose layer for asyn that handles all the "outer" protocol issues and leaves only the user data to stream or other device support. See the asyn documentation and some example interpose layers in asyn.
Eric Norum
[email protected]
hex stream processing with StreamDevice? Barker, Alan M.
RE: hex stream processing with StreamDevice? Mark Rivers
RE: hex stream processing with StreamDevice? Barker, Alan M.
Re: hex stream processing with StreamDevice? Dirk Zimoch
Prev: Re: Asyn and I/O intr scanning Eric Norum
Next: Re: msi again Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: hex stream processing with StreamDevice? Dirk Zimoch
Next: RE: hex stream processing with StreamDevice? Mark Rivers
