1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm meter
To: Wesley Moore <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 23 Aug 2010 12:20:37 -0500
I've had the same problem.
IIRC there are some widgets that use or could use information
which is available via DBR_GR_xxx CA transfers but which
do not properly track changes of the data attributes (such as units or limits).
It looks like these attributes are only fetched when a connection is
created and then cached by EDM.
FWIW - Till
On 08/23/2010 11:57 AM, Wesley Moore wrote:
EDM users/knowledgeable,
I like that a meter can use HOPR and LOPR for setting it's scale. Is there a way to update the meter when HOPR/LOPR change without having to reopen the screen? My interest is for a power meter that has different scales so I want the edm meter to update accordingly.
Wesley
Re: edm meter Andrew Johnson
edm meter Wesley Moore
Prev: edm meter Wesley Moore
Next: Re: edm meter Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: edm meter Andrew Johnson
