1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm meter
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Mon, 23 Aug 2010 14:37:26 -0500
On Monday 23 August 2010 13:42:21 Till Straumann wrote:
> Nevertheless, if edm used the attributes it still should see a change in
> e.g., display limit the next time the value updates.
Using DBR_GR_XXX with value monitors could place a fair burden on the IOC though. Filling in a dbr_gr_double structure for instance requires the IOC to call the record type's get_units(), get_precision(), get_graphic_double() and get_alarm_double() routines, and the calling tree to get to them from the db_get_field() that rsrv calls is several levels deep in some cases.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: edm meter Jeff Hill
edm meter Wesley Moore
Re: edm meter Andrew Johnson
Re: edm meter Till Straumann
Prev: Re: edm meter Wesley Moore
Next: RE: edm meter Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: edm meter Till Straumann
