On Monday, August 23, 2010, you wrote:
> I'd like to agree on a
> formal grammar for the substitutions file.
Yay!
> Having looked through the Yacc grammar for dbLoadTemplate I should point
> out that it doesn't currently support empty patterns or substitutions.
> With the addition of the global variables I think it makes sense to
> allow this: file xyz {}
> but I don't see why you'd need to be able to write either of these as
> well: file xyz {{}}
> file xyz { pattern {} {} }
So, let us talk about semantics before we formalize the syntax. As I
understand it,
file <filename> { <list-of-substitution-lists> }
should mean:
For each substitution-list in <list-of-substitution-lists> insert
content of file named <filename> after performing all substitutions
in scope.
The substitutions in scope inside such a file block are defined to be:
All global substitutions preceding the file block (where later
definitions for the same macro override earlier ones) and additionally
all substitutions defined for the instance, again with later
definitions shadowing earlier ones.
We have two kinds of lists here that may be empty. By natural generalization
of the above definition
* an empty list-of-substitution-lists ("file xyz {}") means: do not insert
anything.
* an empty list of substitutions means insert content of file with only
the global substitutions in scope (if any), thus "file xyz { {} {} }"
would insert the contents of file xyz twice.
Both are occasionally useful, especially when generating or processing
substitution files. Note that while msi is primarily meant to expand
database templates, it is by design *not* restricted to this task. There may
be use cases where inserting the same text more than once make more sense
than it does with record instances.
> Here's what I think the syntax should look like with "global" added,
> expressed in EBNF:
> substitution-file ::= ( global-definitions* template-substitutions+ )+
This looks unnecessarily restrictive to me. Why not simply
substitution-file ::= ( global-definitions | template-substitutions )*
Even an empty substitution file is not completely unreasonable (no file
sections means output nothing). Note that none of the "empty" cases I
propose need special-case semantics, they are pure straight-forward
generalizations.
> global-definitions ::= 'global' '{' variable-definitions '}'
> variable-definitions ::= variable-definition ( ',' variable-definition )*
The comma between definitions is not always required currently (in msi). I
propose to make it strictly optional. This would make generating and writing
substitution files a lot more fool-proof. Note that "," (comma) is not a
value-char, so is not allowed in unquoted values. In fact, ',' does not
begin or end any token (except ',' itself), so there is no ambiguity:
x=1,y=2
gets parsed as
x="1", y="2"
I also (see above) want empty definition-lists, so my (counter-)proposal
here is:
variable-definitions ::= ( variable-definition ','? )*
[In principle one could treat ',' (except inside quoted strings) everywhere
as whitespace, but I'd rather limit it to delimiting list elements. It might
make sense to allow it after file/global blocks and after substitution-
lists, just for consistency.]
> variable-definition ::= variable-name '=' value
> template-substitutions ::= 'file' file-name '{' substitutions? '}'
I'd rather push down the empty case into the variable-substitutions part
(because the latter have a natural empty case, whereas a pattern-definition
must start with a pattern-names clause). Thus
template-substitutions ::= 'file' file-name '{' substitutions '}'
> substitutions ::= variable-substitutions | pattern-substitutions
> variable-substitutions ::= '{' variable-definitions '}'
This should be
variable-substitutions ::= ( '{' variable-definitions '}' )*
> pattern-substitutions ::= 'pattern' '{' pattern-names '}'
> pattern-definitions
> pattern-names ::= variable-name ( ',' variable-name )*
See my comments wrt variable-definitions, i.e. this should be
pattern-names ::= ( variable-name ','? )*
> pattern-definitions ::= ( '{' pattern-values '}' )+
Again, I see no reason to exclude the empty case, so
pattern-definitions ::= ( '{' pattern-values '}' )*
> pattern-values ::= value ( ',' value )*
pattern-values ::= ( value ','? )*
> variable-name ::= variable-name-char+
> file-name ::= file-name-char+ | double-quoted-string |
> single-quoted-string
> value ::= value-char+ | double-quoted-string |
> double-quoted-string ::= '"' (double-quoted-char | escaped-char)* '"'
> single-quoted-string ::= "'" (single-quoted-char | escaped-char)* "'"
> double-quoted-char ::= [^"\]
> single-quoted-char ::= [^'\]
> escaped-char ::= '\' .
> Currently dbLoadTemplate_lex.l defines the remaining terminals to be
> variable-name-char ::= value-char
> file-name-char ::= value-char
> value-char ::= [a-zA-Z0-9_+:./\<>;[] | '-' | ']'
> I would prefer something like these instead
> variable-name-char ::= [a-zA-Z0-9_]
> file-name-char ::= [a-zA-Z0-9_+:./\] | '-'
> but such a change might break existing substitutions files.
I'd like to agree with this proposal, as we already broke compatibility when
introducing scopes, and I never understood the reason for being so liberal
with variable names. In fact, I would further limit them to
variable-name ::= variable-name-start-char variable-name-char*
variable-name-start-char ::= [a-zA-Z]
like in most programming languages (LISP being the only exception I am aware
of). On the other hand, adapting substitution files to the new scoping rules
is trivial (if tedious, just add the missing definitions), but adapting
variable names could be quite disruptive; we might want to be careful here.
For reference, I have attached the complete grammar with the changes I
proposed.
Cheers
Ben
Hahn-Meitner-Platz 1, 14109 Berlin
Vorsitzende des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
Stellvertretende Vorsitzende: Dr. Beatrix Vierkorn-Rudolph Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Disclaimer automatically attached by the E-Mail Security Appliance
mail0.bessy.de 08/24/10 at Helmholtz-Zentrum Berlin GmbH.
pattern-substitutions ::= 'pattern' '{' pattern-names '}' pattern-definitions
file-name ::= file-name-char+ | double-quoted-string | single-quoted-string
value ::= value-char+ | double-quoted-string | single-quoted-string
value-char ::= [a-zA-Z0-9_+:./\<>;] | '-' | '[' | ']'
- Re: msi again Andrew Johnson
- msi again Benjamin Franksen
- Re: msi again Benjamin Franksen
Re: GNU make 3.82 problem Eric Norum
<2010>
2025
2026
<2010>
2025
2026
