1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Windows XP Cygwin cannot find -lCom
To: <[email protected]>
Cc: [email protected]
Date: Mon, 30 Aug 2010 09:42:18 -0500
I wonder if the problem could be the "." in your path in m.verdier?  Try renaming that directory and see if you get the same error.
It should definitely build on cygwin-x86 unless you have the problem with the wrong version of "make".
I believe cygwin-x86 and win32-x86-cygwin are different.  The former requires the Cygwin DLL at run time, the latter does not.
Sent: Mon 8/30/2010 9:44 AM
To: Mark Rivers
Cc: Hu, Yong; [email protected]
I changed my epics\base\configure\CONFIG_SITE file to set :
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
On Make, The error message is the same.
Then, I kept these parameters and I tried to build it using "HOST_ARCH=cygwin-x86" (after a make clean uinstall) : the lib file "epics\lib\cygwin-x86\Com.lib" has been generated and the message is the same.
collect2: ld returned 1 exit status
make[4]: *** [antelope.exe] Error 1
make[4]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope/O.cygwin-x86'
make[3]: *** [install.cygwin-x86] Error 2
make[3]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope'
make[2]: *** [antelope.install] Error 2
make[2]: Leaving directory `/home/m.verdier/epics/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/home/m.verdier/epics/src'
make: *** [src.install] Error 2
Any other idea ???
-----"Mark Rivers" <[email protected]> a écrit : -----
A : "Hu, Yong" <[email protected]>, <[email protected]>
De : "Mark Rivers" <[email protected]>
Date : 30/08/2010 16:19
cc: <[email protected]>
Objet : RE: Windows XP Cygwin cannot find -lCom
I have not built for HOST_ARCH=win32-x86-cygwin but I have built for HOST_ARCH=cygwin-x86, and there you must use SHARED_LIBRARIES=NO and STATIC_BUILD=YES.
Sent: Mon 8/30/2010 9:09 AM
To: [email protected]
It seems you have Windows object(static library) 'Com.lib', but you're trying to link 'antelope.exe' with dynamic(shareable) library. Check out the build options 'STATIC_BUILD' and 'SHARED_LIBRARIES' in the configure file /base***/configure/CONFIG_SITE.
Yong
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Monday, August 30, 2010 10:01 AM
To: Mark Rivers
The build "Com" library file is located here with the name "Com.lib" :
C:\cygwin\home\m.verdier\epics\lib\win32-x86-cygwin\Com.lib
A : <[email protected]>, <[email protected]>
Date : 30/08/2010 15:41
Did it previously successfully build the "Com" library in this location:
If so, what is the name of the file?
From: [email protected] on behalf of [email protected]
Sent: Mon 8/30/2010 8:01 AM
Subject: Windows XP Cygwin cannot find -lCom
Hello,
I'm beginner in Epics.
I'm trying to build it on Windows XP with Cygwin (HOST_ARCH=win32-x86-cygwin).
I need some help to solve this build error :
make[4]: Entering directory `/home/m.verdier/epics/src/toolsComm/antelope/O.win32-x86-cygwin'
g++ -o antelope.exe  -LC:\cygwin\home\m.verdier\epics\lib\win32-x86-cygwin       -m32    -mno-cygwin             closure.o error.o l
alr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom
/usr/lib/gcc/i686-pc-mingw32/3.4.4/../../../../i686-pc-mingw32/bin/ld: cannot find -lCom
make[4]: Leaving directory `/home/m.verdier/epics/src/toolsComm/antelope/O.win32-x86-cygwin'
make[3]: *** [install.win32-x86-cygwin] Error 2
Thanks.
Max
RE: Windows XP Cygwin cannot find -lCom M . VERDIER
RE: Windows XP Cygwin cannot find -lCom Mark Rivers
RE: Windows XP Cygwin cannot find -lCom Hu, Yong
Prev: RE: Windows XP Cygwin cannot find -lCom Mark Rivers
Next: RE: Windows XP Cygwin cannot find -lCom M . VERDIER
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Windows XP Cygwin cannot find -lCom M . VERDIER
