1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: msi again
To: [email protected]
Date: Mon, 30 Aug 2010 10:09:02 -0500
Hi Ben,
On Thursday 26 August 2010 09:59:49 Benjamin Franksen wrote:
> > However this should result in a warning message, which I added to
> > dbLoadTemplate yesterday:
> > file xyz { pattern {} {1} }
> I would say this is an error.
> More generally speaking, the number of pattern-values should always be
> equal to the number of pattern-names. Of course, this goes beyond what we
> can specify with a context free grammar, so it must be stated (and checked)
> separately.
dbLoadTemplate allows you to provide fewer pattern-values than pattern-names
and only defines macros for the pattern-values you've given it.  This allows
global and command-line settings to provide defaults, although of course you
can only omit values from the end of the list.  It also used to silently
accept more pattern-values than pattern-names, but it now prints a warning
message if you do that (and discards them as before).
I don't know whether MSI supports this behaviour or not, but I think we have
to keep it in dbLoadTemplate.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
msi again Benjamin Franksen
Re: msi again Andrew Johnson
Re: msi again Benjamin Franksen
Prev: Re: Windows XP Cygwin cannot find -lCom Geoff Savage
Next: RE: Windows XP Cygwin cannot find -lCom M . VERDIER
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: msi again Benjamin Franksen
Next: Re: msi again Tim Mooney
