Lewis,
No, the software is multithreaded. The images I mentioned were black and
white and if you switch to colour compression (which is more expensive)
the CPU load goes up to around 220% at times.
This is all implemented as an areaDetector plugin in a single IOC. I
don't know what would happen if you tried to use two IOC's on one host,
but I suspect the gains would be minimal. Clearly, if you used a second
host system you would get a doubling of everything.
As I understand it the frames are lost before they leave the Prosilica
driver. The GigE standard is real-time UDP and since we have multiple
independent data sources with no bandwidth allocation I think if you
looked carefully you would see data bits all over the floor. I feel
having the system die reasonably gracefully when the incoming Ethernet
pipe chokes is the best we can do - even if the choke point is
significantly less than the full theoretical bandwidth.
Cheers,
Nick
-----Original Message-----
[mailto:[email protected]] On Behalf Of J. Lewis Muir
Sent: 01 September 2010 15:33
To: EPICS Tech-Talk
Subject: Re: areaDetector video (Was: network video)
On 9/1/10 7:14 AM, [email protected] wrote:
> As a guide, on an Intel X5260 processor (Dell 2950) with 3 1024x768
Mono
> cameras @ 30fps uses 30% of 1 core for acquisition and another 35-40%
> for compression. The compressed stream is about 10% of the
uncompressed
> stream. However, despite the data from the three cameras only being
> 70Mbytes/sec, only one core being utilised so another core is idle,
and
> it being a fully switched network, if you add another camera then
frames
> start being dropped. So, as they say, your mileage may vary.
Hi, Nick.
If only one core is being utilized, perhaps the software isn't written
to take advantage of the other core. In this case, the behavior you
observed doesn't seem so surprising: 30% + 40% = 70%. 70% / 3 = 23% per
camera. One might then anticipate that adding another camera would run
the CPU usage up to 70% + 23% = 93% which might be high enough to cause
frames to get dropped.
Is there a way to run more than one instance of your software? When
software isn't written to take advantage of more than one core, you can
sometimes overcome this if you can run more than one instance of the
software; the operating system will take care of scheduling the second,
third, etc. software process on other cores.
Lewis
- RE: areaDetector video (Was: network video) Mark Rivers
- Re: areaDetector video (Was: network video) J. Lewis Muir
- network video John Dobbins
- Re: network video emmanuel_mayssat
- RE: network video Mark Rivers
- areaDetector video (Was: network video) emmanuel_mayssat
- RE: areaDetector video (Was: network video) nick.rees
Regsitration for the hotel during the EPICS meeting Dalesio, Leo
<2010>
2025
2026
<2010>
2025
2026
