1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: access security file
To: Pierrick Hanlet <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 3 Sep 2010 16:05:40 -0500
Hi Pierrick,
On Friday 03 September 2010 15:41:36 you wrote:
> You started a statement at the end of the email.  Was this meant for me?
Sorry, I got interrupted and didn't review the message properly before sending
it.
I was actually wrong about this being in Base, but we have make rule here that
uses the C preprocessor to generate access security files, allowing us to
include common files and substitute variables.  If you have a way of getting
the list of host-names for your subnet from something like LDAP you could use
that with a script to generate a HAG list that names all those hosts.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
access security file Pierrick Hanlet
Re: access security file Andrew Johnson
Prev: Re: access security file Andrew Johnson
Next: Build IOC linking external *.lib file failed zhangning2095
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 06 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
