1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cPCI
To: "leige" <[email protected]>, <[email protected]>
Date: Tue, 7 Sep 2010 11:17:50 -0400
Hi Leige,
You might also be interested in looking at the following which includes
a library for PCI bus access like the devLib VME interface in EPICS
Base.
http://epics.hg.sourceforge.net/hgweb/epics/devlib2/
Three big caveats though:
1) This assumes OS support for your CPU board.  This is more an issue
with RTEMS/vxWorks then with Linux.
2) This is new code.  I plan on making the initial release shortly.  The
RTEMS and vxWorks implementations have been well tested, but the Linux
implementation has not.
3) The Linux implementation works as a user-space driver.  With Linux
the choice between kernel or user-space driver is something that needs
to be considered carefully for each device.  (a user-space driver is not
the best choice for a fast digitizer like the Aquiris devices that Yong
mentions).
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of leige
> Sent: Tuesday, September 07, 2010 10:09 AM
> To: [email protected]
> Subject: cPCI
> Dear all,
> I'am seeking comments and suggestions on cPCI. Do (or did) you use
cPCI
> as the EPICS IOC? Could you tell me the module name, manufacture, and
> operating system you select for it? A hardware group in our project
> prefers to use cPCI to construct their low levle controls and ask if
it
> can be ported to EPICS. I searched tech-talk but the clues are only a
> few. So please give me some comments on this.
> Thank you very much,
> Ge
Time stamp question Andrew Wagner
Re: Time stamp question Andrew Johnson
cPCI leige
Prev: RE: cPCI Hu, Yong
Next: Please do not hijack threads [was: cPCI] Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
