1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Examples of synApps scaler record using asyn port driver
Date: Wed, 08 Sep 2010 13:22:47 +1000
On Tue, 2010-09-07 at 21:39 -0500, Mark Rivers wrote:
> mca/mcaApp/SISSrc/drvMcaSIS/drvMcaSIS3820Asyn.c is an example asyn driver that supports the scaler record.  It is a relatively complex driver, because it supports not only the scaler record interface, but also the mca record interface.  The driver allows the SIS3820 to be used as a simple preset scaler (like the Joerger VSC16).  It also allows it to be used as a multi-channel scaler (MCS), with each input counting into an array as a function of time or external channel advance.  The time per point can be as small as 1 microsecond or so.
> If you only are interested in the preset scaler mode, then most of the code in this driver is not necessary because it is supporting the MCS mode.
> mca/iocBoot/iocVxWorks/SIS3820_32.cmd is an example vxWorks startup script which loads a scaler record.  The scaler record itself is loaded from std/stdApp/Db/scaler32.db.
Thank you Mark, this looks very good for a reference. I'd only been
looking inside the std/ top-level directory, which is why I hadn't seen
it.
Cheers,
Angus
Examples of synApps scaler record using asyn port driver Angus Gratton
RE: Examples of synApps scaler record using asyn port driver Mark Rivers
Prev: RE: Examples of synApps scaler record using asyn port driver Mark Rivers
Next: [no subject] Ahn, Si Won
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Examples of synApps scaler record using asyn port driver David Kline
ANJ, 08 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
