1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS on x86_64?
To: John Dobbins <[email protected]>, EPICS Techtalk <[email protected]>
Date: Wed, 08 Sep 2010 10:41:50 -0400
Hi:
At the SNS, we're not using 64 bit Linux, so no effort is made to test our
CSS products on 64 bit.
Fundamentally, though, it seems to run when I quickly try it on a machine
that happens to be 64 bit.
uname -a
Linux ics-srv-epics1.ics.sns.gov 2.6.9-89.0.19.ELsmp #1 SMP Wed Dec 30
12:52:55 EST 2009 x86_64 x86_64 x86_64 GNU/Linux
java -version
java version "1.6.0_19"
Java(TM) SE Runtime Environment (build 1.6.0_19-b04)
Java HotSpot(TM) Server VM (build 16.2-b04, mixed mode)
CSS 2.2.0 starts up OK.
The Channel Access library plugin does NOT contain 64 bit binaries, so you
will have to use the pure java CAJ version (CSS, Preferences, ..., EPICS,
When you cannot launch CSS at all, try to run it like this:
  css -consoleLog
There should be some error related to wrong Java version.
You will have to use a Sun/Oracle Java, not the GNU java compiler.
You can also try
   css -consoleLog -vmargs -d32
to actually use the 32 bit version of Java.
Kay
On 9/8/10 10:12 , "John Dobbins" <[email protected]> wrote:
> All,
> I had previously installed CSS 2.0.1 under Linux x86.
> i.e.
> http://ics-web.sns.ornl.gov/css/updates/apps/sns_css_2.0.1-linux.gtk.x86.zip
> We are testing an x86_64 Linux and find that we cannot launch CSS. Is there
> any way to run CSS on a 64 bit machine?
> Thanks,
> John Dobbins
> Lab for Elementary Particle Physics
> Cornell University
CSS on x86_64? John Dobbins
Prev: CSS on x86_64? John Dobbins
Next: Re: Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: issues with drvEtherIP V2.19 - ControlLogix 5000 PLC via EtherNet/IP Jeff Hill
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
