1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Testing the new DBE property in EPICS R3-14-11
To: [email protected]
Date: Thu, 16 Sep 2010 11:20:00 -0500
On Thursday 16 September 2010 08:57:37 Ralph Lange wrote:
> I would think that camonitor for the complex structures would yield a
> hard to read, if not unusable output.
We could provide an option to output the complex structures using JSON,
although it might be better to provide this functionality in a separate
program.  Suggested output:
tux% cajson -d DBR_CTRL_DOUBLE -mvap anj:aiExample
  "anj:aiExample": {
    "field_type": "DBF_DOUBLE",
    "value": 0,
    "status": "UDF",
    "severity": "INVALID",
    "units": "Volts",
    "precision": 1,
    "lower_disp_limit": 0,
    "upper_disp_limit": 10,
    "lower_alarm_limit": null,
    "lower_warning_limit": null,
    "upper_warning_limit": null,
    "upper_alarm_limit": null,
    "upper_ctrl_limit": 0,
    "lower_ctrl_limit": 10,
I'm using "null" for NaN values since JSON doesn't permit them in numerics,
although I guess they could be expressed as "nan" instead.  I think each CA
monitor event should output a complete JSON object, although I'm not sure
whether parsers will like this.  The cajson program could use -m to mean
monitor and do a ca_get_callback if you don't specify it.
Having created the above example I realize one problem with the DBR_CTRL_xxx
types is that they don't include a time-stamp, so they're not very good for
monitoring values that change over time.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Testing the new DBE property in EPICS R3-14-11 Xu, Chengcheng
Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
Prev: Re: controlling cross compiled build products Andrew Johnson
Next: Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
