1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: softIOC and SIGHUP
To: [email protected]
Date: Fri, 17 Sep 2010 15:53:30 -0700
Hello all,
Hello,
I am running into a puzzling problem with a softIOC on Linux. The IOC
is running on fairly standard x86 PC hardware under a custom Linux
distribution (buildroot/busybox/uclibc/base-3.14.11). The IOC is
normally started with /usr/bin/nohup, so that one can ssh to the unit,
restart the IOC and disconnect. This worked very well until I've
transitioned from older linuxthreads to NPTL. Now the IOC dies when it
gets SIGHUP, even when started under nohup.
A bit of digging showed that the IOC installs a handler and unblocks
SIGHUP when it calls epicsSignalInstallSigHupIgnore() during iocInit.
It seems to me it might be better to check first if SIGHUP is ignored
and only modify settings if it isn't.
Dmitry Teytelman
Re: softIOC and SIGHUP Ralph Lange
Prev: Reservations at the Cronwe Plaza Long Island Dalesio, Leo
Next: RE: o.c.swt.widgets: Improve intensity graph drawing performance by using pixel lookup table. Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: softIOC and SIGHUP Ralph Lange
ANJ, 20 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
