1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Soft IOCs and Port Numbers
To: [email protected]
Date: Fri, 24 Sep 2010 12:10:08 -0500
On Friday 24 September 2010 11:24:42 Ralph Lange wrote:
>   On 24.09.2010 12:16, Eric Norum wrote:
> > Or run every IOC in it's own virtual machine?
> Have been investigating that- too thick. Running a VM only to have an
> additional IP address .... nah.
> I would prefer the solution that uses virtual network interfaces on the
> soft IOC host. Relatively slim, completely transparent, does not need
> additional services.
But it does require configuring a alias interface and providing an IP address
for each soft IOC you want to run.  If you're using non-routable addresses the
extra IPs may not be a major issue (as long as your subnets were made large
enough), but it might mean getting IT involved every time Controls wants to
add a new soft IOC.  Do you have to configure CA clients running on a machine
with multiple interfaces to only use one of them for broadcasts, or would CA
take care of that for you if they're all in the same subnet?
A machine-specific name-server would be more efficient since each PV name
request only has to be checked once by the name-server rather than by all of
the IOCs on the machine.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: Soft IOCs and Port Numbers Jeff Hill
Soft IOCs and Port Numbers Pam Gurd
Re: Soft IOCs and Port Numbers Eric Norum
Re: Soft IOCs and Port Numbers Ralph Lange
Prev: RE: Soft IOCs and Port Numbers Dalesio, Leo
Next: RE: Soft IOCs and Port Numbers Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Soft IOCs and Port Numbers Jeff Hill
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
