1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Soft IOCs and Port Numbers
To: "'Matthieu Bec'" <[email protected]>
Cc: [email protected]
Date: Fri, 24 Sep 2010 11:19:17 -0600
> Would it be backward compatible for older CA clients/servers trying to
> connect the single-host multiple IOCs?
With multicast clients would send search messages to a special
ip address. That could be manually configured with
EPICS_CA_ADDR_LIST, but we could easily also allow the distribution
to be configured so that sending to the broadcast addresses,
multicast address, name server, no particular address is the
default. We could probably also allow a default configuration, set
in the distribution, which sends to more than one of the above.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Matthieu Bec [mailto:[email protected]]
> Sent: Friday, September 24, 2010 11:01 AM
> To: Jeff Hill
> Subject: Re: Soft IOCs and Port Numbers
> On 09/24/10 08:33, Jeff Hill wrote:
> >> We are wondering here, how to host multiple soft
> >> IOCs on the same computer, possibly
> >> sharing the same UDP CA request port.
> > It is a simple matter to add multicast support to the
> > ca server, and that will address this issue.
> Of the different options I heard, it seems most transparent.
> Matthieu
> Matthieu Bec              Gemini Observatory
> Tel: +56 51 205785        c/o AURA, Casilla 603
> Fax: +56 51 205650        La Serena, Chile
Soft IOCs and Port Numbers Pam Gurd
RE: Soft IOCs and Port Numbers matthew.pearson
RE: Soft IOCs and Port Numbers Anze Zagar
RE: Soft IOCs and Port Numbers Jeff Hill
Re: Soft IOCs and Port Numbers Matthieu Bec
Prev: RE: Soft IOCs and Port Numbers Jeff Hill
Next: Re: Soft IOCs and Port Numbers Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Soft IOCs and Port Numbers Matthieu Bec
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
