1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long string ...
To: [email protected]
Date: Fri, 24 Sep 2010 21:18:39 -0500
caput myStringout.VAL$
Remember, .VAL is the default field if a field is not specified.
On 9/24/2010 9:14 PM, [email protected] wrote:
I just read the following:
The IOC can now make long string fields accessible via CA
  â Enabled by appending â$â to the field part of the PV name
      â e.g. record.NAME$
  â The â$â is a Field Modifier which changes the reported type of the PV
    from DBR_STRING to an array of DBR_CHAR
  â The â$â suffix only works on string and link fields
What does that mean?
I renamed my PV 'myStringout$':
caput myStringout$ "011234567890123456789012345678901234567890..."
caput myStringout$.NAME$ "..."
doesn't work...
Any idea?
Re: Long string ... emmanuel_mayssat
Prev: Long string ... emmanuel_mayssat
Next: always more inputs in gensub/asub emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Long string ... emmanuel_mayssat
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
