1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice slowdown
To: "Mark Rivers" <[email protected]>
Cc: [email protected]
Date: Sun, 26 Sep 2010 15:25:30 -0700
To check the raw transfer speed I did:
	 telnet  -c  192.168.1.159 73 >/dev/null
and typed in the 'Waveform?\n" command.
The times per megasample for 16 megasamples in this case:
10.25
10.24
10.24
10.25
10.24
10.25
10.24
10.25
10.24
10.25
10.24
10.25
10.24
10.25
10.24
10.24
So I'm pretty sure that the slowdown is in the StreamDevice processing somewhere.
By way of comparison, here are the 16 'seconds per megasample' values when using ASYN/StreamDevice rather than telnet:
16.78
48.18
80.91
113.86
147.28
180.20
211.65
244.36
278.61
308.90
342.91
374.54
408.60
439.26
473.29
505.54
On Sep 26, 2010, at 2:40 PM, Mark Rivers wrote:
> Have you turned on asynTrace in the low-level (TCP?) driver and sent the output to a file so it does not slow things down too much?  Can you see then what's on the wire?
> Mark
Eric Norum
[email protected]
RE: StreamDevice slowdown Mark Rivers
StreamDevice slowdown Eric Norum
Prev: Re: StreamDevice slowdown Eric Norum
Next: RE: StreamDevice slowdown Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
