1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Rocket Engine control
To: "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
Date: Tue, 28 Sep 2010 14:01:43 +0200
Scott,
I suggest you start with a list of hardware components you have to control and then look if EPICS provides drivers for all of them.
For a single-ioc test stand you are relatively free in your choice of a control system because you won't see many of EPICS' advantages for a multi-ioc network.
If 1000 samples per second is much or not depends on the size of a sample (1 ADC channel or several mega pixel detectors?) and of the number of seconds you run the measurement. (A rocket will burn out after a small number of second, right?)
Dirk
Akridge, Charles S. (MSFC-ES52) wrote:
I work for NASA and looking for examples of where EPICS is used for low-speed (1000 samples per sec) data acquisition of rocket engine stand or some related type control. We want to determine if EPICS is the right solution.
I don’t foresee (limited knowledge though) any reason EPICS would not work but it would be easier to make my case to the project if we had an example.
Any help is much appreciated.
Scott
Rocket Engine control Akridge, Charles S. (MSFC-ES52)
Prev: error compiling base R3-14-11 gabriele marano
Next: Re: error compiling base R3-14-11 Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Rocket Engine control Akridge, Charles S. (MSFC-ES52)
Next: StreamDevice slowdown Eric Norum
ANJ, 28 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
