1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CALC expression
To: <[email protected]>
Date: Tue, 28 Sep 2010 19:25:41 -0400
Hi Emmanuel,
Agree and not only that: 0.00835 actually becomes an intelligible:parm.VAL/DESC
Regards
Matthieu
On 09/28/10 18:58, [email protected] wrote:
No one suggested this but ... you can also put your constant as input!
0.00835 then becomes D, etc...  with just that change you saved 12 chars!
E
On 13:03 Tue 28 Sep , Andrew Wagner wrote:
Hey everyone,
I need to evaluate a somewhat complicated conditional statement in a calc record. Presently I need to evaluate:
field(CALC, "(235>B&& 5>D&& 5>E) ? (B*0.00835 - 0.7> A + (C-B)*0.25 ? B*0.00835 - 0.7: A + (C-B)*0.25): 0")
where the letters are input variables. When I load the record I get the error
Can't set "VOLT:PID.CALC" to "(235>B&&  5>D&&  5>E) ? (B*0.00835 - 0.7>  A + (C-B)*0.25 ? B*0.00835 - 0.7: A + (C-B)*0.25): 0"
Error at or before ")" in file "MagnetCtrlApp/Db/MagnetCtrl.db" line 113
Does CALC not support nested evaluations? Perhaps I need a subroutine record? Any advice would be greatly appreciated.
Cheers,
Andrew
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
CALC expression Andrew Wagner
Re: CALC expression emmanuel_mayssat
Prev: Re: CALC expression Andrew Johnson
Next: Re: archiving system Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CALC expression emmanuel_mayssat
Next: EPICS Registration - we need to close this to get our final counts. Dalesio, Leo
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
