1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CALC expression
To: [email protected]
Date: Wed, 29 Sep 2010 11:02:29 -0500
Hi Tim,
On Wednesday 29 September 2010 00:47:16 Tim Mooney wrote:
>   I like the idea of increasing the size of the CALC field.  I'd suggest
> 80.
Thanks for that suggestion
> The RPCL field is private, so it might be left at its current size for
> most expressions, and reallocated for the occasional long expression.
That would not be acceptable; the RPCL field is a fixed length char array, so
we can't change its size for individual record instances.  I don't want anyone
being able to crash my IOC by writing long versions of the expression 1?1:1?
1:1?1:1?1:1 into the CALC field (1?1:1 expands to 31 bytes in postfix, and
each additional 1?1: adds another 21 bytes â there's a macro in postfix.h that
calculates the RPCL size needed from the CALC size).
We *could* make RPCL into a char* pointer and allocate it dynamically
according to the particular expression, but that means making code changes to
the record and also opens up the possibility of free memory fragmentation on
vxWorks IOCs (none of the other standard record types allocate memory after
initialization to avoid that).  I think it's too late to make those kind of
changes at this point.
Alternatively we could add integer literal support to the code in libCom/calc,
which would reduce the incremental expansion factor from 21/4 to 10/3 or
better, but again that would be making code changes uncomfortably late in the
development cycle for 3.14.12.
> I would not worry /too/ much about wasted space.  After all, every record
> has a 41-character DESC field, most of them are permanently empty, and I
> don't recall hearing complaints about that.
Making CALC 80 translates to RPCL being 419 bytes instead of its current 209
bytes.  Lewis' suggestion of 64 bytes translates to RPCL being 335 bytes.
Do any small-IOC guys want to weigh in on these suggestions?
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: CALC expression Eric Norum
Re: CALC expression Pam Gurd
Re: CALC expression Tim Mooney
CALC expression Andrew Wagner
Re: CALC expression Andrew Johnson
Prev: Re: LabVIEW interfaces with EPICS Dr. Holger Brand
Next: Re: CALC expression Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CALC expression Tim Mooney
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
