1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiving system
To: "Steven M. Hartman" <[email protected]>
Date: Wed, 29 Sep 2010 10:27:00 -0700
Martin, Steven,
I like the idea of having a RDB to do channel archiving.
But compared to files it obviously increases the complexity.
I like the possiblities of the SQL queries and using widespread-used tools.
I went through the doc and it says that Oracle can handle 8000 pv updates per second.
Were any benchmark done with a mysql backend?
The doc you suggested to read is relatively high level.
I couldn't find a way to generate the Xml files they are talking about or download the data collection deamon.
Ultimately the population of the database (creation of tables) should be 'automated' and starting from a
'dbl <recordType> > ... '.
But the doc mentions we should be using eclipse and this and that.
For this simple operation, that seems a little complicated and overkill...
But Martin, if you make any progress, let me know... I may just follow in your footsteps.
E
>> Where can we find source code and documentation? Our questions are
>> still very basic: How to build the data collection deamon? How to setup
>> the tables in the RDB? And how to configure which PV are collected?
> Some introductory documentation can be found here . . .
> https://ics-web.sns.ornl.gov/css/devel.html#archiver
> Steven Hartman
> [email protected] || 865-466-6473
Emmanuel
Re: archiving system Ralph Lange
Re: archiving system Steven M. Hartman
archiving system Dirk Martin
RE: archiving system james.rowland
Re: archiving system John William Sinclair
Re: archiving system Martin Konrad
Prev: Re: CALC expression Andrew Johnson
Next: RE: CALC expression Redman, Russell
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: archiving system Steven M. Hartman
Next: Re: archiving system Ralph Lange
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
