1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cross compiling EPICS for cris v10
Cc: [email protected]
Date: Thu, 30 Sep 2010 15:57:47 +0200 (CEST)
Hello Mark,
On Thu, 30 Sep 2010, Mark Rivers wrote:
Did you first build EPICS base, which according to your output should be located in:
Does this mean, I have to build EPICS base after I have edited the CONFIG_SITE file? If so, I haven't build EPICS base first. But if I try, I also get an error:
/usr/local/cris/bin/cris-axis-linux-gnu-gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_cris_ -mlinux -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -Wdeclaration-after-statement -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -mno-mul-bug-workaround -march=v10 -g -mlinux -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/perl5/5.8.8/i386-linux-thread-multi/CORE -isystem /usr/local/devboard-R2_20//target/cris-axis-linux-gnu/include -isystem /usr/local/devboard-R2_20//target/cris-axis-linux-gnu/usr/include Cap5.c
cc1: unrecognized option `-Wdeclaration-after-statement'
make[3]: *** [Cap5.o] Error 1
make[3]: Leaving directory `/usr/Epics/base-3.14.10/src/cap5/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/base-3.14.10/src/cap5'
make[1]: *** [cap5.install] Error 2
make[1]: Leaving directory `/usr/Epics/base-3.14.10/src'
make: *** [src.install] Error 2
../../../../base-3.14.10/include >
How did you define EPICS_BASE in your IOC-tree configure/RELEASE file? It looks to me like you defined it with a relative path? Try defining it with an absolute path.
It was defined with a relative path. I've changed it.
What is your EPICS_HOST_ARCH environment variable, linux-x86?
Yes, EPICS_HOST_ARCH is set to linux-x86
Does the file ../../../../base-3.14.10/lib/linux-x86/librecIoc.a exist? That's where it should be located according to the output I see.
Yes, this file exists.
Normally you edit the CONFIG_SITE in EPICS base configure/ directory to set global settings for all EPICS applications at your site.
From: [email protected] on behalf of Florian Feldbauer
Sent: Thu 9/30/2010 7:04 AM
To: [email protected]
Subject: Cross compiling EPICS for cris v10
Hello,
I'm triing to cross compile EPICS for a cris v10 architecture but having
some problems.
We are using here EPICS base 3.14.10 and synApps 5.4.1 (StreamDevice and
Asyn).
According to the README.cris in the EPICS bsae documentations one has to
edit the CONFIG_SITE files. Which one? The ones in the EPICS base
directory, or the ones in the directory of my IOC-tree?
I've tried the second option and ending up with the error message
make[3]: Entering directory
`/usr/Epics/slowCtrl_etrax/slowCtrlApp/src/O.linux-cris_v10'
/usr/local/cris//bin/cris-axis-linux-gnu-gcc -c
-Wall      -mno-mul-bug-workaround -march=v10     -g -mlinux -fPIC -I.
-I../../../../base-3.14.10/include/os/Linux
-I../../../../synApps/synApps_5_4_1/support/sscan/2-6-4/include
-I../../../../synApps/synApps_5_4_1/support/calc/2-7/include
-I/usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/include
-I/usr/Epics/synApps/synApps_5_4_1/support/stream/2-4/include
../xxxRecord.c
../devXxxSoft.c
../dbSubExample.c
../slowCtrlHello.c
../initTrace.c
make[3]: *** No rule to make target
`../../../lib/linux-cris_v10/librecIoc.a', needed by
`libslowCtrlSupport.a'.  Stop.
make[2]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Can anyone tell me, what I did wrong?
Best regards,
Florian
RE: Cross compiling EPICS for cris v10 Mark Rivers
Cross compiling EPICS for cris v10 Florian Feldbauer
Prev: RE: Cross compiling EPICS for cris v10 Mark Rivers
Next: RE: Cross compiling EPICS for cris v10 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
