1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS at Sandia
From: "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
To: Andrew Johnson <[email protected]>, tech-talk <[email protected]>
Cc: "Akridge, Charles S. \(MSFC-ES52\)" <[email protected]>
Date: Mon, 4 Oct 2010 15:42:51 -0500
Andrew,
Thanks for your response.
I just emailed our contact at White Sands to see what he knows.
Are you aware of it being used at White Sands?
Thanks for your help.
Scott
> From: Andrew Johnson <[email protected]>
> Date: Mon, 4 Oct 2010 15:15:42 -0500
> To: tech-talk <[email protected]>
> Cc: "[email protected]" <[email protected]>
> Hi Scott,
> On Monday 04 October 2010 14:47:52 Akridge, Charles S. (MSFC-ES52) wrote:
>> A NASA group is traveling to White Sands Test Facility in late October
>> (around the 27th) and we¹re considering using EPICS for a low-speed (1000
>> samples/sec) data acquisition system for the propulsion test stands and
>> would like to see EPICS in use at Sandia National Labs. Is anyone willing
>> or can you give me a contact to possibly set-up a tour?
> If you know anyone at White Sands that uses EPICS you may be better off
> contacting them directly.  There are at the moment no subscribers to tech-talk
> with a sandia.gov email address, and only two messages in the archive, both
> dated 2003.
>> NOTE: I sent this message out originally Friday afternoon and thought it
>> may have gotten overlooked that¹s why the second try.
> In this case I think the silence means there's nobody here that can answer
> your request.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Re: EPICS at Sandia Andrew Johnson
Prev: Re: EPICS at Sandia Andrew Johnson
Next: EPICS Collaboration Meeting - arrival instructions Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Driver Needed Akridge, Charles S. (MSFC-ES52)
ANJ, 05 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
