1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: subscription updates
To: "'Patrick Thomas'" <[email protected]>, <[email protected]>
Date: Sat, 9 Oct 2010 15:24:04 -0600
Hi Patrick,
So I will concur with Ben. This is of course
the classic consumer producer situation. If the
producer rate exceeds consumer rate no amount of
buffering will help long term, and robust client side
software should always concede at least a small
probability that the server might produce at a rate
faster than the lower priority server threads in the
IOC, network, or client side application can handle.
One can greatly reduce occurrence rates of discarded
intermediate values by reducing CPU loading competing
with the IOC's per client thread, by streamlining
the network layers, and by streamlining the client
side application. Frequently the issue is something the
client side application does that reduces throughput
like writing too few bytes per IO request to the disk,
formatting text, and or writing to standard out.
In summary, occurrence rates can be reduced but a
client side application intolerant of situations where
intermediate events are discarded might not be an
a realistic / general-purpose design.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Patrick Thomas
> Sent: Friday, October 08, 2010 4:43 PM
> To: [email protected]
> Subject: subscription updates
>   Hi,
> The channel access reference manual states that:
> There is unfortunately no field in the protocol allowing the server to
> indicate that an intervening subscription update was discarded.
> Is there a way to ensure that an intervening subscription update will
> not be discarded? Would you have to ensure that each callback executes
> in a certain amount of time, ie, faster that the channel update
> interval?
> Thank you,
> Patrick
subscription updates Patrick Thomas
Prev: Re: Linux libraries for areaDetector Kate Feng
Next: StreamDevice-2-4 compile error Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subscription updates Ben Franksen
Next: gateway putlog pthomas
ANJ, 11 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
