1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling an iocsh "sub-script"
To: [email protected]
Date: Wed, 13 Oct 2010 18:45:27 +0200
On Mittwoch, 13. Oktober 2010, Josh Stein wrote:
> I would like to point out one warning with these embedded scripts -
> there is a very real possibility of breaking some higher level tools
> which rely on 'crawling' the startup command files for information.
> This very issue has just cropped up here at APS when the st.cmd
> structure of a number of our production IOCs was cleaned up during a
> recent 3.14 upgrade.
> In essence, some of our crawlers were unable to parse relevant tags
> since they failed to show up in the st.cmd file itself as those tags
> were moved to one or more of the 'sub-scripts'.
> For now, the crawlers at APS are being re-written to follow the
> indirection. This is yet another example of how fragile the system
> structure can grow over time; the hooks into various parts actually
> increase the risk of things breaking as time progresses.
Yup. Reverse engineering installed files is a simple and clever solution
to the practical problem of finding out what is actually installed. But
*of course* it is liable to break whenever the *structure* of the
installed stuff changes.
The obvious solution to the dilemma is to create a central service that
serves as source to both the installed files *and* the big picture
(e.g. Irmis) and presumably other stuff like alarm handlers etc. But
how can we design something like that while still retaining the easy
editability (and the ability to use version control systems) that we
have with plain text files? This is the million dollar question we have
been discussing at BESSY ever since it became clear that a growing
number of Oracle database tables (with a specific set of tables for
each kind of device/application) is *not* an easily editable and
maintainable solution in the long run.
Cheers
Ben
Re: Calling an iocsh "sub-script" J. Lewis Muir
Calling an iocsh "sub-script" Angus Gratton
RE: Calling an iocsh "sub-script" Mark Rivers
Re: Calling an iocsh "sub-script" Josh Stein
Prev: Re: EPICS CA problems Tim Mooney
Next: Re: EPICS CA problems Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Calling an iocsh "sub-script" Josh Stein
Next: Re: Calling an iocsh "sub-script" J. Lewis Muir
ANJ, 13 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
