1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error)
Date: Wed, 13 Oct 2010 14:43:12 -0700
Hi Tech-Talk,
    To use the TurboPMAC VME board with a PPC mother board to control motors, I am trying to integrate tmac-3-7 with synApps_5_5 and epics/base-3-14-11 for my IOC named 21idbnp. I am having the following problem. Any clues to its resolution or a workaround would be greatly appreciated.
tpmac-3-7 compiles with synApps. I added the statement "ioc21idbnpVX_DBD+=pmacInclude.dbd" to 21idbnpApp/src/Makefile. pmacInclude.dbd includes statusRecord.dbd, tsubRecord.dbd, statusDevice.dbd, pmacAsynIPPort.dbd, pmacAsynMotor.dbd, pmacAsynCoord.dbd, and add_pmac.dbd. Then I compile the 21idbnp IOC that includes the tpmac libraries (pmacAsynCoord, pmacAsynIPPort, pmacAsynMotor, pmacIoc). This compiles for vxWorks without error.
When I load the munch file to vxworks, I get the following error.
ld(0,0,"21idbnp.munch")
Undefined symbol: pvar_dset_devPmac (binding 1 type 0)
Undefined symbol: pvar_dset_devPmacRamStatus (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
For my investigation, I see the following:
1. when compiling the IOC, -lpmacIoc, -lpmacAsynCoord, -lpmacAsynIPPort, and -lpmacAsynMotor are used with ld to create 21idbnp.
2. grep using the string "pvar_dset_devPmac" in the IOC directory results in the following:
      a. binary file 21idbnp.munch matches.
      b. ioc21idbnpVx_registerRecordDeviceDriver.cpp has references to pvar_dset_devPmac.
      c. binary file 21idbnp matches.
      d. binary file ioc21idbnpVx_registerRecordDeviceDriver.o matches.
      e. 21idbnp.nm has references to pvar_dset_devPmac.
3. Same results as #2 above for string "pvar_dset_devPmacRamStatus"
Jay Steele
XRadia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) J. Lewis Muir
Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) Andrew Johnson
Prev: Re: Calling an iocsh "sub-script" J. Lewis Muir
Next: Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS CA problems Mark Rivers
ANJ, 27 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
