1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway putlog
To: [email protected]
Cc: [email protected]
Date: Fri, 15 Oct 2010 09:22:45 -0500
Hi Patrick,
On Friday 15 October 2010 03:45:48 [email protected] wrote:
> I'm sorry, I'm not quite sure I understand. I did a grep for
> asTrapWriteRegisterListener and logClientSend in the gateway source code
> and did not get any results. Is there code in the gateway source somewhere
> that does the logging to the file that is specified on the command line?
Sorry for leading you astray, I'm sitting next to Ralph in an EPICS workshop
and we've just worked out that we were both wrong (probably led by my assuming
that the gateway would use the asTrapWrite facility, which it apparently
doesn't after all).
You should look initially at the routines gateVcChan::write() and
gateVcChan::writeNotify() in gateVc.cc which do the value put logging in the
gateway code, plus a couple of other places, look for the callers to
getPutlogFp() for those.  There are various related routines for setting the
put-log file name and the file pointer it is written to, but you should be
able to trace those through by tracing through the member functions and
variable names used.
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
gateway putlog pthomas
Re: gateway putlog Ralph Lange
Re: gateway putlog pthomas
Prev: Re: Problem in registerRecordDeviceDriver Andrew Johnson
Next: INLINK with PP and Asynchronous Device Support Schoeneburg, Bernd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gateway putlog Ralph Lange
Next: StreamDevice-2-4 compile error Burkhard Kolb
ANJ, 15 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
