No you don't need anything, monitors are just matter of creating the
channel with the factory, and then subscribe to the events as shown in
the web page (http://gfa-it.web.psi.ch/epicsSharp/index.php?site=examples).
If you need to access the channels via some gateway or others then you
will have either to configure your EpicsClient inside the code or
provide the app.config
Sincerely,
Alain Bertrand
On 18/10/2010 17:16, Jose Patricio Gonzalez wrote:
Hello
I'm starting to use the Epics C# Library
(http://gfa-it.web.psi.ch/epicsSharp) with the EPICS monitor included
in that page, but I'm unable to read data from that monitor with the
examples
What do I have to set to run it? do I need some external libraries?
Thanks so much !
Joe
- Epics C# Library - questions Jose Patricio Gonzalez
RE: EPICS CA problems Mark Rivers
RE: Eurotherm Temperature Controller Support emma.shepherd
<2010>
2025
2026
Lookup table problem Silver
<2010>
2025
2026
ANJ, 21 Oct 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
