1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04)
To: tech-talk <[email protected]>
Date: Fri, 22 Oct 2010 11:40:00 +1100
Is anyone running MEDM on a recent GNOME environment, Linux x64? (Better
yet, Ubuntu 10.04?)
I'm having an unusual issue. Both MEDM 3.1.4 and 3.1.5 compile and run,
and seems fine for most uses. I'm able to run sample interfaces, for
example scaler.adl runs perfectly.
The problem occurs when I right-click (button3-click) on an MEDM
surface.
In execute mode, this immediately locks up my X11 session and I can't
interact with anything from then on (all I can do is move the mouse
pointer around.)
In edit mode, it locks up interaction in the same way (without showing
the editing menu), but it also traps the mouse pointer inside the
particular window for the ADL I have open.
In both cases, the only way I can get out is to switch to a text virtual
console (ie Ctrl-Alt-F2) and kill the medm process from there.
Running medm under ltrace, I can see function calls for all UI events up
to the right-click, but nothing for the right-click itself. Which makes
me think this may be an interaction between GNOME (or some other piece
of software) and MEDM or Motif.
I'm running with Motif 2.2.3 (standard package.) Any/all help, or
suggestions of how to proceed with investigation, would be very much
appreciated. :)
Angus
Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Matthieu Bec
Prev: Re: cross-gcc-2.9.6 problem zhuangjian
Next: Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cross-gcc-2.9.6 problem Dirk Zimoch
ANJ, 25 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
