1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ChannelArchiver build problem with 3.14.11 on Suse linux
Date: Tue, 26 Oct 2010 14:04:09 -0700
I am able to build a 32 bit version of the ChannelArchiver from sourceforge under R3-14-11 with some changes to cater to my local environment and one change to ArchiveDataServer.cpp (see patch). However, I am doing this on 32 bit linux.
[mshankar@cdlx27 ChannelArchiver]$ uname -a
Linux cdlx27 2.6.9-89.29.1.ELsmp #1 SMP Fri Sep 24 05:11:14 EDT 2010 i686 i686 i386 GNU/Linux
[mshankar@cdlx27 ChannelArchiver]$ cat /proc/version
Linux version 2.6.9-89.29.1.ELsmp ([email protected]) (gcc version 3.4.6 20060404 (Red Hat 3.4.6-11)) #1 SMP Fri Sep 24 05:11:14 EDT 2010
I checkout the latest HEAD from sourceforge.
cvs -z3 -d:pserver:[email protected]:/cvsroot/epicschanarch co -P ChannelArchiver
Apply the patch to ArchiveDataServer.cpp
[mshankar@cdlx27 src]$ cd ChannelArchiver/
[mshankar@cdlx27 ChannelArchiver]$ patch -i /scratch/Work/ChannelArchiver/ArchiveDataServer.cpp.patch XMLRPCServer/ArchiveDataServer.cpp
patching file XMLRPCServer/ArchiveDataServer.cpp
I have installed a later version of XML-RPC and Xerces in /opt/local so I have to make some changes to accommodate that.
export PATH=/opt/local/bin:${PATH}
[mshankar@cdlx27 ChannelArchiver]$ xmlrpc-c-config --version
1.23.99
[mshankar@cdlx27 ChannelArchiver]$ ls -ltr /opt/local/lib/libxerces-c*
lrwxrwxrwx  1 root root       18 Sep 21 15:24 /opt/local/lib/libxerces-c.so -> libxerces-c-3.1.so*
-rwxr-xr-x  1 root root     1113 Sep 21 15:24 /opt/local/lib/libxerces-c.la*
-rwxr-xr-x  1 root root 23935920 Sep 21 15:24 /opt/local/lib/libxerces-c-3.1.so*
-rw-r--r--  1 root root 55748180 Sep 21 15:24 /opt/local/lib/libxerces-c.a
Make some changes to make.cfg to cater to my local environment
[mshankar@cdlx27 ChannelArchiver]$ diff make.cfg make.cfg.original
45d44
< USR_CXXFLAGS += -I/opt/local/include
48c47
< XMLRPCBASE=/opt/local
> XMLRPCBASE=$(LOCAL)
52c51
< USR_LDFLAGS += -L/opt/local/lib -lxerces-c
> USR_LDFLAGS += -L$(LOCAL)/lib -lxerces-c
Make one change to the xmlrpc-config-wrapper_original to cater to the newer release of XMLRPCServer
[mshankar@cdlx27 ChannelArchiver]$ diff XMLRPCServer/xmlrpc-config-wrapper XMLRPCServer/xmlrpc-config-wrapper_original
6c6
<   1.*) client="client"
>   1.0*) client="client"
I am now able to complete make
make[2]: Leaving directory `/scratch/Work/ChannelArchiverBuildTest/src/ChannelArchiver/Manager/O.linux-x86'
make[1]: Leaving directory `/scratch/Work/ChannelArchiverBuildTest/src/ChannelArchiver/Manager'
[mshankar@cdlx27 ChannelArchiver]$ ls -ltr Manager/O.linux-x86/
total 1652
-rw-rw-r--  1 mshankar cd     297 Oct 26 13:53 ascii.depends
-rw-rw-r--  1 mshankar cd     194 Oct 26 13:53 Makefile
-rw-rw-r--  1 mshankar cd  204904 Oct 26 13:53 main.o
-rw-rw-r--  1 mshankar cd     719 Oct 26 13:53 main.depends
-rw-rw-r--  1 mshankar cd  120500 Oct 26 13:53 ascii.o
-rwxrwxr-x  1 mshankar cd 1335163 Oct 26 13:53 ArchiveManager*
Let me know if you are still having issues and we'll see if we can find a 64 bit linux to test the compilation on.
Murali
Attachment: ArchiveDataServer.cpp.patch
Description: ArchiveDataServer.cpp.patch
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Kasemir, Kay
Prev: Re: EPICS on ARM (continued) emmanuel_mayssat
Next: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
ANJ, 26 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
