1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OMS MAXv announces fix
To: Kurt Goetze <[email protected]>
Cc: [email protected]
Date: Thu, 28 Oct 2010 09:26:22 -0500
Kurt,
Good question.
OMS believes, but is not 100% certain, that MAXv boards with
s/n 575 and less are not effected by this "manufacturer component
change" problem. (I am guessing this may be do to their inability
to track exactly which boards have which versions of a component
or component combinations.)
My suggestion is that if a MAXv board experiences a watchdog
timeout, that board should definitely be returned to OMS for repair.
(I addressed detecting a watchdog timeout in an earlier tech-talk
post here.) Otherwise, if your MAXv board's s/n is less that 575,
and you are NOT experiencing any problems, I see not reason to
return it to OMS for repair at this time.
Ron
On 10/27/2010 3:30 PM, Kurt Goetze wrote:
Ron,
Phil Brown's letter implies that there is a range of boards affected,
because the problem started when "a change in a component by the
manufacturer ... worked into our supply".  So there is a lower limit
to the serial numbers, below which we don't need to worry about
the problem.  Does OMS know, in terms of serial numbers, about
where the problem crept in?  I don't want to send back any boards
unnecessarily.
Kurt
On 10/27/2010 3:00 PM, Ron Sluiter wrote:
 With their permission, I am passing along an announcement
from OMS concerning the reliability of their MAXv motor controller.
The short synopsis is; there was a problem, they have diagnosed it,
all boards after s/n 966 are fixed and they are offering to fix any boards
before s/n 967 for free.
Ron
OMS MAXv announces fix Ron Sluiter
Re: OMS MAXv announces fix Kurt Goetze
Prev: YACAQ (Yet Another Channel Access Question) Benjamin Franksen
Next: epicsEvent Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OMS MAXv announces fix Kurt Goetze
Next: Re: OMS MAXv announces fix Dirk Zimoch
ANJ, 29 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
