1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsEvent
To: "'Eric Norum'" <[email protected]>, "'Ben Franksen'" <[email protected]>
Cc: "'EPICS Techtalk'" <[email protected]>
Date: Thu, 28 Oct 2010 16:32:53 -0600
On WIN32:
http://msdn.microsoft.com/en-us/library/ms682396%28VS.85%29.aspx
"When the state of an auto-reset event object is signaled, it remains
signaled until a single waiting thread is released; the system then
automatically resets the state to nonsignaled. If no threads are waiting,
the event object's state remains signaled."
I suppose that the only issue with being more specific about behavior will
be encountering a new os where that behavior is inefficient to reproduce.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Eric Norum
> Sent: Thursday, October 28, 2010 3:44 PM
> To: Ben Franksen
> Cc: EPICS Techtalk
> Subject: Re: epicsEvent
> Well, the vxWorks and RTEMS implementations of epicsEvent use simple
> binary semaphores.  The POSIX implementation also looks like it will also
> provide the semantics of a simple binary semaphore.   The WIN32 version I
> have no idea about.
> Assuming that the WIN32 does provide the desired semantics maybe we should
> update the documentation to state that this is how epicsEvents are to
> work.
> On Oct 28, 2010, at 2:30 PM, Ben Franksen wrote:
> > The documentation of libCom/osi/epicsEvent in the Developer's Guide
> > carefully avoids saying anything about what happens if an event gets
> > signalled and more than one thread waits for the event to happen.
> > The name "event" and most of what's written in the docs suggest that
> > *any* thread waiting for an event will be able to continue as soon as
> > the event gets signalled.
> > If this is true, how do I get the effect of a (binary) semaphore, i.e.
> > only one thread waiting on the semaphore will continue, the others have
> > to wait until the semaphore is given again?
> > Or, if it is false, i.e. epicsEvent really acts like a binary semaphore,
> > I suggest that this be more clearly stated in the docs. It should also
> > be stated how the library or system choses the thread to run; in
> > VxWorks, this can be influenced when creating the semaphore (FIFO or
> > priority based), but if other systems do not allow such a distinction
> > then it should be explicitly stated in the documentation that no
> > assumptions should be made about which thread is chosen. Note that this
> > severely complicates things if you want e.g. FIFO semantics, because
> > you'd have to implement all the queueing yourself.
> > Thanks
> > Ben
> Eric Norum
> [email protected]
epicsEvent Ben Franksen
Re: epicsEvent Eric Norum
Prev: Re: epicsEvent Till Straumann
Next: Re: epicsEvent Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsEvent Andrew Johnson
Next: Re: epicsEvent Till Straumann
ANJ, 28 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
