1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamDevice2(stringin) problem!
To: =?x-gbk?q?=BB=C6=D2=BB=C3=F9?= <[email protected]>
Cc: [email protected]
Date: Fri, 29 Oct 2010 13:50:41 +0200
Hello Yiming
That problem looks strange. In streamApp.dbd you should find a line like
device(stringin,INST_IO,devstringinStream,"stream")
This line defines that stringin records with DTYP "stream" have INST_IO link type, not CONSTANT. At the moment I have no idea how you can have a CONSTANT link there.
Please send the complete boot output of our ioc.
Dirk
»ÆÒ»Ãù wrote:
Hello
I have a problem in streamDevice2.
I use the streamDevice to control a VME monitor. As the example in streamApp,I have three files: vme.cmd,
vme.db,vme.proto.These are parts of them:
vme.cmd
!./streamApp
dbLoadDatabase "O.Common/streamApp.dbd"
streamApp_registerRecordDeviceDriver
#where can protocols be located?
epicsEnvSet "STREAM_PROTOCOL_PATH", ".:protocols:../protocols/"
#setup the busses
#example serial port setup
drvAsynSerialPortConfigure "COM1", "/dev/ttyS0"
asynOctetSetInputEos "COM1",0,"\r\n"
asynOctetSetOutputEos "COM1",0,"\r\n"
asynSetOption ("COM1", 0, "baud", "9600")
asynSetOption ("COM1", 0, "bits", "8")
asynSetOption ("COM1", 0, "parity", "none")
asynSetOption ("COM1", 0, "stop", "1")
asynSetOption ("COM1", 0, "clocal", "Y")
asynSetOption ("COM1", 0, "crtscts", "N")
dbLoadRecords "vme.db","PREFIX=VME"
#dbLoadRecords "scalcout.db","PREFIX=DZ"
iocInit
#enable debug output
var streamDebug 1
      vme.db
record(stringin, "$(PREFIX):T2") {
  field(DTYP, "stream")
  field(INP, "@vme1.proto spyT2 COM1")
  field (SCAN, "I/O Intr")
record(stringin, "$(PREFIX):T3") {
  field(INP, "@vme1.proto spyT3 COM1")
     vme.proto
Terminator =" ";
ReplyTimeout = 10000; # 10 sec is very long, for keyboard input
ReadTimeout = 2500;   # also long for keyboard input
spyT2{
   in "T2:%2c";
spyT3 {
in "T3:%2c";
Last month,it works well, I can get the value from the VME monitor with it.
Recently,I install CSS_EPICS_2.3.0-boy, I want to desire a manager display for it.
But the problem happened.This is the error :
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Aug 19 2010
2010/10/29 10:15:03.397 _main_ VME:HA: Wrong link type CONSTANT
2010/10/29 10:15:03.398 _main_ VME:HA: Record initialization failed
2010/10/29 10:15:03.398 _main_ VME:S1: Wrong link type CONSTANT
2010/10/29 10:15:03.398 _main_ VME:S1: Record initialization failed
2010/10/29 10:15:03.399 _main_ VME:HA: No businterface attached
2010/10/29 10:15:03.399 _main_ VME:HA: Can't start "I/O Intr" protocol
2010/10/29 10:15:03.399 _main_ VME:S1: No businterface attached
2010/10/29 10:15:03.399 _main_ VME:S1: Can't start "I/O Intr" protocol
It works bad ,I don't know why this happen.I run "example.cmd","test.cmd",they have the
same problem.Interesting,only "stringin" record performs error,others run well.
Please help me,looking forward to your reply.
Yiming
streamDevice2(stringin) problem! 黄一鸣
Prev: Re: OMS MAXv announces fix Dirk Zimoch
Next: cygin-x86-debug behavior Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: streamDevice2(stringin) problem! 黄一鸣
ANJ, 29 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
