1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Adding readback zeroing to an asyn analog input
To: tech-talk <[email protected]>
Date: Mon, 01 Nov 2010 12:22:08 +1100
I'm writing to request some advice. I have an asyn port driver for a
"Group 3 Type G" stepper motor controller.
The controller board has a simple register-based interface, which suits
us because we don't have any complex motor positioning requirements. One
register is written for "desired position" and another register is read
back for "current position" (in steps).
So, until now I've gone with simple asynInt32 support for the steppers,
instead of a motor record.  I was just modelling the desired position as
an ao record and the current position as an equivalent ai record, using
the generic asyn device support for both.
However, there has been a request for "zeroing" the position values - ie
resetting both the current and desired positions to zero without moving
the motor.
This is supported trivially in the controller, I just need to flip a
register bit to send a "zero value" command and the hardware registers
will reset to zero on their own.
I can't think of a simple (and non-hacky) way to implement this support
in the asyn port driver, and then all the way up to the database layer.
Does anyone have any suggestions? Will the motor record support this, if
I write asyn motor record support instead? (I looked at the motor record
documentation and wasn't sure.)
Thanks in advance (yet again!)
Angus
RE: Adding readback zeroing to an asyn analog input Mark Rivers
Prev: readline for iocSh Rod Nussbaumer
Next: RE: Adding readback zeroing to an asyn analog input Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
