1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: monitors received out of order
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 02 Nov 2010 11:52:43 -0400
Jeff Hill wrote:
I find Jeff's response ambiguous, and maybe that's the problem. Jeff says
there is a per client event queue. Tim seems to imply it is per-
subscription. Ralf seems to imply the truth is somewhere in between, and
since it is more specific it has the ring of truth about it.
It depends on which server it is. The rsrv server (and current IOC behavior)
is how Ralph describes, but PCAS and the new server are slightly better at
preserving event ordering, but will still discard intermediate events if the
producer is faster than the consumer.
Did Tim describe the problem as "out of order" or "missing event" ?
Cheers,
Kate
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
-----Original Message-----
On Behalf Of [email protected]
Sent: Tuesday, November 02, 2010 3:27 AM
To: [email protected]
Subject: RE: monitors received out of order
Hi All,
I read Tim's initial post with interest because I am sure that I was told
at an early EPICS training course (probably in 1992 or 93) that monitors
posted to a given client within a given lockset were guaranteed to be
received in order (and, conversely, ca_puts from a client were delivered
in order). I have since used this for a lot of systems that need to
collect a coherent block of information. I have not known it to fail, but
I haven't looked for the 1 in a million problem, just the 1 in 100 or so.
Now this old wives tale is clearly being challenged.
Was my memory ever true? I have a suspicion that by the tone of his
message Tim may have been labouring under the same misapprehension. It may
have changed, for example, when we lifted the fixed (read 16k) CA limit. I
would agree with Tim in that in my experience it is true most of the time
- especially on vxWorks, and since I have mostly used it to get
synchronised hard real-time data from a server to a client, vxWorks is
where I have used it.
I am not sure what to do about it now, but I definitely have a frequent
requirement to get a coherent set of data from a server. Up till now, I
have monitored everything and then taken a snapshot whenever I got a
monitor from the last item in a processing chain (which I have ensured
always updates whenever the chain processes). This has seemed to work with
VxWorks servers. I would like to still be able to achieve the same effect.
How else can I do this?
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Jeff Hill Sent: 01 November 2010 21:42 To: 'Tim Mooney'; 'EPICS tech-talk' Subject: RE: monitors received out of order
Hi Tim,
The Channel Access publish and subscribe system is a classic
consumer/producer situation. The producer is of course record
processing and the consumer is the Channel Access client side
application. In basic queuing theory, it is known that no
matter how big the finite buffer capacity between the producer
and the consumer, all of it will be consumed if the production
rate is even a marginal amount faster than the consumption rate.
Furthermore, to prevent one client from disrupting subscription
updates sent to another client, each client attaching to an IOC
is serviced out of a per-client dedicated event queue connecting
the higher priority database processing threads with the lower
priority per-client server threads. So to avoid consuming all
available memory this event queue is finite length, and if full
capacity is reached the last event on the queue for a particular
subscription is replaced; this has the net impact of causing an
intermediate subscription update to be discarded.
So one can easily see, given the above design with intermediate
events being discarded when the producer out-paces the consumer,
that events will sometimes be delivered out of order when comparing
different channel subscriptions, but that events will never be
delivered out of order within a single channel subscription.
HTH
Jeff
[email protected]]
On Behalf Of Tim Mooney
Sent: Monday, November 01, 2010 3:10 PM
To: EPICS tech-talk
Subject: monitors received out of order
Dear folks,
I have two records, and a separate task monitoring a field that both
records
post, all in the same IOC. Most of the time, my task receives monitors
in
the
order in which they were posted. But sometimes, the task receives a
monitor
from record B before it receives a previously posted monitor from record
A.
(I know for sure which record is posting first, because record A posts
before
causing record B to process. Also, I've modified the record to set its
time
stamp immediately before posting, and I get another time stamp on entry
to
the monitor routine.  The time ordering of those stamps does not agree.)
I've seen this on solaris and Linux, but not on vxWorks.
I have code that misbehaves when this happens, so I started digging
around
and have convinced myself that I should not be relying on the time
ordering of
monitors received from different records (even when those records are
running
in the same task).  I now think I can rely on posts from a single record
arriving in
time order, but not posts from different records.  I think this because
events from
different record go into different queues, and there doesn't seem to be
any code
in the vicinity that seems worried about time ordering across event
queues.
Am I right about this?
Tim Mooney ([email protected]) (630)252-5417
Software Services Group, Advanced Photon Source, Argonne National Lab.
-- This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
monitors received out of order Tim Mooney
RE: monitors received out of order Jeff Hill
RE: monitors received out of order nick.rees
Prev: Re: monitors received out of order Kate Feng
Next: RE: monitors received out of order Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: monitors received out of order Jeff Hill
ANJ, 02 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
