1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Firewall (iptables) issues?
To: "Mark Rivers" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Thu, 4 Nov 2010 08:36:40 -0700
Agreed, but what's the trick to permitting broadcasts?   The network interface parameters seem to have this enabled:
eth0      Link encap:Ethernet  HWaddr 00:16:76:A7:BC:5E
          inet addr:128.3.128.30  Bcast:128.3.131.255  Mask:255.255.252.0
          inet6 addr: fe80::216:76ff:fea7:bc5e/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:11205136 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1376343 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1796814589 (1.6 GiB)  TX bytes:398736094 (380.2 MiB)
          Memory:e0080000-e00a0000
On Nov 4, 2010, at 8:24 AM, Mark Rivers wrote:
> Hi Eric,
> I suspect the problem is that the broadcast messages from the client are not making it through the firewall.  I had a similar problem with a Windows firewall.
> You can run ethereal on another machine and see if it is seeing the client broadcasts.
> Mark
Eric Norum
[email protected]
Firewall (iptables) issues? Eric Norum
RE: Firewall (iptables) issues? Mark Rivers
Prev: RE: Firewall (iptables) issues? Mark Rivers
Next: Re: Firewall (iptables) issues? Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
