To conclude this thread, this solution works, provided I use edm 1-12-33 or greater. I'm using edm 1-12-38 with epics R3.14.8.2. I found that caget -t appends a blank character to the result. So, to use the result in the name of the embedded window file, I had to strip that off with sed. Without doing this, the name was constructed as "pdu_trig_PP0 .edl" which did not exist. Here is how it looks: echo \'`caget -t TRIG:LI20:201:MODE`\''PP0 ' echo \'`caget -t TRIG:LI20:201:MODE | sed 's/[ \t]*$//'`\''PP0' In the .edl file that launches the related display, I set the macro MODE=`caget -t TRIG:LI20:201:MODE | sed 's/[ \t]*$//'` and it works. Dayle Kotturi On Wed, 3 Nov 2010, John William Sinclair wrote: Hi Dayle,
| ANJ, 04 Nov 2010 |
Home
News
About
Talk
Base
Modules
Extensions
