1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Firewall (iptables) issues?
To: EPICS Techtalk <[email protected]>
Date: Fri, 5 Nov 2010 14:31:00 -0700
Thanks to input from Jeff Hill, Ralph Lange, and Andrew Johnson I think that the following is an accurate description of the firewall settings needed to support channel access.
If you want channel access clients on a machine to be able to see beacons and replies to broadcast PV search requests you need to permit inbound UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064) or destination port EPICS_CA_REPEATER_PORT (default is 5065).  On systems using iptables this can be accomplished by rules like
	-A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
	-A INPUT -s 192.168.0.0/22 -p udp --dport 5065 -j ACCEPT
If you want channel access servers (e.g. "soft IOCs") on a machine to be able to see clients you need to permit inbound TCP or UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by rules like
	-A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
	-A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
The above sets of rules are complete assuming that there's no blocking of outbound traffic.
In all cases the "-s 192.168.0.0/22" specifies the range of addresses from which you wish to accept packets.
Eric Norum
[email protected]
RE: Firewall (iptables) issues? Jeff Hill
Re: Firewall (iptables) issues? Till Straumann
Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Ralph Lange
Prev: RE: Options for reviving old Allen Bradley PLC implementations Al Honey
Next: RE: Firewall (iptables) issues? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Firewall (iptables) issues? Ralph Lange
ANJ, 05 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
