1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Cross-compilation missing library
To: EPICS tech-talk <[email protected]>
Date: Tue, 16 Nov 2010 12:21:36 -0800
I am trying to compile the sequencer on arm.
I am using a cross toolchain.
I am apparently missing the flex library for the arm toolchain.
Is there a way to install the flex library for arm on my linux 64b?
If so, how?
perl ../sncVersion.pl 2.0.12 > sncVersion.c
/usr/local/opt/crosstool/arm-linux/gcc-3.3.4-glibc-2.3.2/bin/arm-linux-gcc -c
-D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_ARM_NWFP_
-DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall           -I. -I../O.Common -I.
-I.. -I../../../include/os/Linux -I../../../include
-I/usr/local/epics/base/3.14.11/include/os/Linux -I/usr/local/epics/base/3.14.11/include
-I/usr/local/opt/crosstool/arm-linux/gcc-3.3.4-glibc-2.3.2/arm-linux/include  sncVersion.c
/usr/local/opt/crosstool/arm-linux/gcc-3.3.4-glibc-2.3.2/bin/arm-linux-g++ -o snc
-L/usr/local/epics/base/3.14.11/lib/linux-armv4tl
-Wl,-rpath,/usr/local/epics/base/3.14.11/lib/linux-armv4tl
-Wl,-rpath-link,/usr/local/epics/base/3.14.11/lib/linux-armv4tl
-L/usr/local/opt/crosstool/arm-linux/gcc-3.3.4-glibc-2.3.2/arm-linux/lib
snc_main.o parse.o phase2.o gen_ss_code.o gen_tables.o snc.o sncVersion.o   -lrecIoc
-lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc
-lca -lCom  -lfl
/usr/local/opt/crosstool/arm-linux/gcc-3.3.4-glibc-2.3.2/lib/gcc-lib/arm-linux/3.3.4/../../../../arm-linux/bin/ld:
cannot find -lfl
collect2: ld returned 1 exit status
make[3]: *** [snc] Error 1
make[3]: Leaving directory
`/usr/local/epics-armv4tl/extras/3_14_11-20101027_120536/seq/2-0-12-20101116_120930/src/snc/O.linux-armv4tl'
make[2]: *** [install.linux-armv4tl] Error 2
make[2]: Leaving directory
`/usr/local/epics-armv4tl/extras/3_14_11-20101027_120536/seq/2-0-12-20101116_120930/src/snc'
make[1]: *** [snc.install] Error 2
make[1]: Leaving directory
`/usr/local/epics-armv4tl/extras/3_14_11-20101027_120536/seq/2-0-12-20101116_120930/src'
make: *** [src.install] Error 2
Emmanuel
Re: Cross-compilation missing library Andrew Johnson
Prev: RE: the hex instruction convert peter.owens
Next: Re: Cross-compilation missing library Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: the hex instruction convert Dirk Zimoch
ANJ, 16 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
