1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ca_put_callback once again
To: "'Ben Franksen'" <[email protected]>, "'EPICS Techtalk'" <[email protected]>
Date: Mon, 22 Nov 2010 09:42:13 -0700
> ben@sarun[3]: .../seq/work > time caput -c -w5 pvPutAsync1 1 &; sleep
> 1;
> time caput -c -w5 pvPutAsync2 1
> [1] 32140
> Old : pvPutAsync1                    Low
> Old : pvPutAsync2                    Low
> New : pvPutAsync2                    High
> caput -c -w5 pvPutAsync2 1  0,00s user 0,01s system 22% cpu 0,036 total
> New : pvPutAsync1                    Low
> caput -c -w5 pvPutAsync1 1  0,00s user 0,00s system 0% cpu 2,034 total
> [1]  + done       time caput -c -w5 pvPutAsync1 1
Since this is an issue with how the database is implemented I will let Andrew answer
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Ben Franksen
> Sent: Sunday, November 21, 2010 5:13 PM
> To: EPICS Techtalk
> Subject: ca_put_callback once again
> Hi Everyone
> I have made more experiments with ca_put_callback and discovered what I
> think is a serious bug.
> Imagine a CA client issuing a ca_put_callback and waiting for the
> callback. This might take a while because of asynchronous records being
> processed and waiting for their processing to complete. This processing
> can be caused either directly by the put, or indirectly (via forward or
> PP output links, maybe PP input links too). All this is documented in
> the Developer's Guide under putNotify. So far so good.
> Now imagine another ca_put_callback happens, which triggers processing
> of another network of records and this set overlaps with the first one
> above, while the first request is still in progress.
> What will happen? My original thought was that this might depend on
> whether the two calls come from the same client or from two different
> clients. This is not the case, however, except in the special case that
> both calls in fact target the same record. In this case, requests from
> the same client will be queued in the server, whereas requests from
> different clients behave as in the general case to which I come now.
> If the two calls target different records, but the processing chains
> (or
> networks) overlap, then what happens is that the second call
> *immediately* gets a *successful* callback.
> This is not what I expected. I had assumed that the CA server would
> send
> back an error to the second client, saying that there is already
> another request pending. Indeed, there is an error code in caerr.h,
> namely
> #define ECA_PUTCBINPROG     DEFMSG(CA_K_ERROR,     45)
> that I assumed is there for this case. Not so.
> The problem is that this defeats the whole purpose of the
> ca_put_callback resp. putNotify which is to make sure that the
> processing really has completed. If another client, *any* client
> anywhere on the control network happens to issue a call that interferes
> with mine it might be that I get a success callback even though nothing
> has completed yet.
> This is a bug, IMO. If a client specifically asks for a callback to
> make
> sure something it wishes to happen in the server has actually happened,
> then the server must either wait for completion, however long it takes,
> or else respond with an error.
> BTW, the scenario can be easily tested, this is my test db file (which
> I
> run with 'softIoc -d <dbfile>'):
> record(bo,"pvPutAsync1") {
>     field(ZNAM,"Low")
>     field(ONAM,"High")
>     field(HIGH,"1")
>     field(OUT,"pvPutAsyncSeq.SELN PP")
> record(bo,"pvPutAsync2") {
>     field(ZNAM,"Low")
>     field(ONAM,"High")
>     field(HIGH,"1")
> record(seq,"pvPutAsyncSeq") {
>     field(SELM,"Specified")
>     field(DLY1,"2")
>     field(DOL1,"1")
>     field(LNK1,"pvPutAsyncRes CA")
> record(longin,"pvPutAsyncRes") {
> This is the test command line and the output:
> 1;
> [1] 32140
> I checked the code in caput.c to make sure that caput reports an error
> in the callback message. It does and as you can see there is no error
> reported. The test was run under 3.14.12-rc1 for the client (the -c
> switch is new), but tests with the sequencer indicate that it happens
> in 3.14.8.2, too.
> Cheers
> Ben
> "Never confuse what is natural with what is habitual."
>                                    -- attributed to Mahatma Gandhi
ca_put_callback once again Ben Franksen
Prev: ca_put_callback once again Ben Franksen
Next: Re: ca_put_callback once again Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 22 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
