1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: fast epid
To: <[email protected]>, <[email protected]>
Date: Tue, 23 Nov 2010 11:47:04 -0600
Hi Pete,
Here’s a message I sent to Philip Taylor at Observatory Sciences recently in response to a similar inquiry.  I’ve included the attachments from that message as well.
Hi Philip,
There is no more documentation on the fast feedback, that needs to be done.
I've attached an example .template file.  The 7 strings parsed are macro parameters to the fast_pid_control.db file.
INPUT:  The name of the asynPort which provides the readback
INPUT_DATA: The asyn "drvInfo" string which is used to identify the data parameter on the asynFloat64 interface.
INPUT_INTERVAL: The asyn "drvInfo" string which is used to identify the input interval parameter on the asynFloat64 interface.  This is a time in seconds beween data samples.  The input driver must provide this number.
ICHAN: The asyn "addr" field for the input driver, i.e. which ADC channel, etc.
OUTPUT:  The name of the asynPort for the output signal
OUTPUT_DATA: The asyn "drvInfo" string which is used to identify the data parameter on the asynFloat64 interface.
OCHAN: The asyn "addr" field for the output driver, i.e. which DAC channel, etc.
The DT field of the EPID record is used to control how often the feedback is done.  It is always an integer multiple of the input callback interval.  If the multiple is greater than 1 then averaging is done in the device support.
The SCAN field of the EPID record is just used to control how quickly a "snapshot" of the actual PID values are done.
I've attached screen shots of the pid_control.adl screen, the pid_parameters.adl screen and the pid_plot_readback screen.
These were all done with the first PID record in the template file.  This is an IP330 input channel 0 connected to DAC output channel 0.  I changed the setpoint (red) and you see the ADC input respond (blue).
I found a bug in the DAC128V driver while putting this together, and have committed a new version here:
https://subversion.xor.aps.anl.gov/synApps/dac128V/trunk/
Let me know if you have more questions or problems.
Cheers,
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, November 23, 2010 11:33 AM
To: [email protected]
Subject: fast epid
Can someone enlighten me as to how to initialise the latest version of the fast epid record?
I used to use the following but the INP field has changed in the latest version
record(epid, "BL18I-OP-DCM-01:FPMTR:FFBS3") {
  field(DTYP, "Fast Epid")
  field(INP, "@ip330 6 DAC1 0")
From the code I can see there are an additional 3 fields in the INP so it now requires all of the following
field(INP,”@<inputName> <inputChannel> <inputDataString> <inputIntervalString> <outputName> <outputChannel> <outputDataString>”)
So what are inputDataString, inputIntervalString, outputDataString?
I guess there is an example somewhere?
Thanks
Pete Leicester
Diamond Light Source
Attachment: pid_fast.template
Description: pid_fast.template
Attachment: pid_control.png
Description: pid_control.png
Attachment: pid_parameters.png
Description: pid_parameters.png
Attachment: fast_feedback.png
Description: fast_feedback.png
fast epid peter.leicester
Prev: fast epid peter.leicester
Next: Re: ca_put_callback once again Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Incorrect get_precision Allison, Stephanie
ANJ, 23 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
