Let me just add one point to clarify the situation as it is.
> > 6. In general a set of records may be processed as a result of
> > a single dbPutNotify. If a record in the set is found to be active,
> > either because PACT is true or because a putNotify already owns the
> > record, then that record is not made part of the set of records
> > that must complete before the putNotify request completes.
I verified that indeed it does not matter *why* the asynchronous record
is active. My example behaves in exactly the same way if I start with a
plain caput (w/o callback), i.e. the second put (the one with callback)
completes immediately.
Cheers
Ben
- ca_put_callback once again Ben Franksen
- Re: ca_put_callback once again Andrew Johnson
- Re: ca_put_callback once again Ben Franksen
RE: Incorrect get_precision Allison, Stephanie
sncseq compiling error 王锐萍
<2010>
2025
2026
RE: ca_put_callback once again Jeff Hill
<2010>
2025
2026
