1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_put_callback once again
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Wed, 24 Nov 2010 14:20:48 -0600
On Wednesday 24 November 2010 13:52:16 Jeff Hill wrote:
> Is it possible to know when initiating a put notify if a put notify is
> already pending in any part of the processing chain that it is being
> initiated, and if so, chain initiation of a subsequent put notify to
> completion of the pending put notify? My naive understanding is that all
> records in the same processing chain share a single lock set lock, and also
> a single put notify queue?
As currently implemented the putNotify subsystem is fully dynamic, it doesn't
know what records will be processed until they are.  I don't see any easy way
to change that since there might be record types such as the seq, fanout or
dfanout where we can't know in advance which links will be processed (the SELN
field value selects one or more links in some modes), and some records might
be disabled using SDIS anyway.  It seems overly restrictive to include the
whole lock-set, there can be multiple non-overlapping putNotify groups within
the same lock-set since nowadays we do not allow an NPP+NMS link to break a
lock-set into two.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: ca_put_callback once again Jeff Hill
Re: ca_put_callback once again Tim Mooney
Re: ca_put_callback once again Andrew Johnson
Prev: RE: ca_put_callback once again Jeff Hill
Next: RE: ca_put_callback once again Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
